Isuzu Oil Sump Rubber
Posted: Sun Oct 13, 2019 9:56 am
by WelshBoy
Hi
I have a 3.1 1994 Td 4JG2 I had to replace the timing case cover gasket done that. Now is it possible to get the U shaped rubber back on between the sump and the timing case without taking out the sump to do so, I have been at it for hours but cannot get it to go back into the groove correctly.
Re: Isuzu Oil Sump Rubber
Posted: Thu Oct 24, 2019 7:31 pm
by handymanny01
I did this exact job years ago on mine..(you prise it off ,, but it wont go back on). its essentially impossible, as the cover is doweled on, and therefor has to go straight on.. the rubber seal to sump is fully in the way of this, so i drilled and tapped the dowels, made tiny slide hammer to remove them..and pulled them out.. then refitted the front cover, then tapped the dowels back in through the cover once id settled the cover down into the seal (with lots of good silicone) and fitted the cover bolts (loosely tightened) Normally the cover would go onto the block first,,, then the sump would get fitted... but sometimes ya gotta get creative when youre in elbow deep on a job!
Posted: Sat Nov 02, 2019 7:25 pm
by WelshBoy
handymanny01 wrote:I did this exact job years ago on mine..(you prise it off ,, but it wont go back on). its essentially impossible, as the cover is doweled on, and therefor has to go straight on.. the rubber seal to sump is fully in the way of this, so i drilled and tapped the dowels, made tiny slide hammer to remove them..and pulled them out.. then refitted the front cover, then tapped the dowels back in through the cover once id settled the cover down into the seal (with lots of good silicone) and fitted the cover bolts (loosely tightened) Normally the cover would go onto the block first,,, then the sump would get fitted... but sometimes ya gotta get creative when youre in elbow deep on a job!
Hi yep that's what I had to do but I got away with just taking out the bottom dowl. But I could not use a new rubber had to use the old one if I had taken out the top dowl I think would have been ok with new rubber. Thanks for the reply
