Coolant system questions for 4JB1T swap into '89 Trooper
manders
Post by manders »
Hello to all!
My gas engine was having problems and I stumbled on a chance to pick up a 4JB1T with the accompanying MUA transmission ... so I jumped!!! :lol:
I've found a good bit of info on this site, PlanetIsuzoo, 4x4wire.com, etc., but nothing that is a 110% answer to my current quandary.
Here's some pics:
Here's my first guess for the "simplest" connections:
B -> C -> Z
and
A -> D -> Y
But I may have those backwards and/or otherwise totally mixed up. :P
As for the oil cooler, I've read in other posts that the 'factory' configuration involves another brass/alloy pipe that connects to the back of the engine and then has a couple heater hoses to connect to the cooler. But since I don't have that ... I'm not even gonna venture a guess about possible connections. :wink:
I appreciate the assistance.
MAnders.
Re: Coolant system questions for 4JB1T swap into '89 Trooper
so long since I had to play with this and its impossible to see in place.
1st pic
A-C and B-D
pic 3
D and C go to Z and Y Not sure what Z is
E goes to either M or N and there should be a T piece in the other pipe pipe to attach the other cooler pipe.
It might be part of the metal pipe assembly that is missing. This also contains a thermostat but it will work without it. You will just have to run straight hoses.
manders
Post by manders »
Thanks for the info, it is very helpful!
geeves wrote:1st pic
A-C and B-D
Might first guess was completely backwards! I've often said that if you give me a 50/50 chance ... I'm 100% certain to screw it up! :wink:
geeves wrote:pic 3
Just to confirm, I think you mean D -> Z, and C -> Y. Correct?
geeves wrote:... Not sure what Z is
Do you mean you are not sure what "X" is? If so, I think this might be an air conditioner condensation outflow, as I cannot make out any potential connection on the 4ZE1 engine.
I appreciate the assistance ...
I could have them wrong as well Always take a top pipe to a top pipe and bottom to bottom to prevent air locks yes I got x and z swapped
manders
Post by manders »
geeves wrote:Always take a top pipe to a top pipe and bottom to bottom to prevent air locks
Now you're just being waaaaaaayyyyy too logical!!! :lol:
Thanks for the confirmations!
These may help although they look a little different to yours.
manders
Post by manders »
These are very helpful, thank you!
P.S. I love Dunedin!!! :smile:
