Ive just been emailed the following. I dont know the engine so better to post it up here for advice
hello mate i was wondering if you could help me i just brought a 4jh1-tc
holden rodeo it seems to be using alot of oil replaced turbo thinking it
was the turbo seal still leaking it looks like it is leaking from up behind
the turbo on the block somewhere .... i dont know im at wits end over this
, blow by is a fair bit , just brought the car and the previous owner is
not taking my phone calls , i am wanting to check the pcv valve but can not
find it i have taken the tapper cover off to find a metal bracket thing
full of oil but no pcv valve ? there is now oil in the new turbo on the
compressor side ? seems like there is to much oil pressure ? im lost mate
and clutching at straws ... the car only has 200,000 km on it . the engine
has started to run away twice and i had to stall it . engine sounds smooth
apart from the pcv hose it vents like an old tractor and thoughts would be
amazing thanks for your time
appreciate it
Adam
from oz
Now my thoughts are the pcv is the same as earlier engines and there is just a light rubber flap inside that housing to prevent blowback. The logical answer seems to be fitting a catch can and draining this back into the dipstick but if blow by is that severe it might be time for new rings.
helping a new member
Re: helping a new member
Has it been a problem since you bought it? IF so with the lack of phone calls i would suggest that he was passing on his problems. WHile im not entirely familiar with the PCV on this engine i know that there is a replaceable PCV listed with supercheap. A PCV wont fix a runaway diesel / ring problem. As above throw a catch can on and see if that has any difference.
yeah mate since i brought it ..... i have up loaded a video and will do more video's tomorrow of oil in turbo ect ect at the end of the video you can see the oil dripping from the pcv hose
https://www.youtube.com/watch?v=k0lvGGJ ... e=youtu.be
These are the workshop manuals for Dmax and Dteq and should cover the 4jh1 motor (I haven't gone through them) hope this can help someone as they are for the spec built for SA.
it's in the mediafire account
looks like it needs a motor rebuild
Believe it or not Ive seen much worse. A catch can will deal with the oil. However hopefully you got it cheap as that engine might be on last legs. One thing to try is changing the oil to a diesel semi synthetic like delo gold or good mineral oil like valvolene diesel extra. My previous bighorn had blowby like that when using repco branded oil at 160k but was fine with both these oils. It was fine at 240k when the body got too rusty
