I am remedying a few issues which the previous owner had tinkered with, one being the power steering pump belt. Currently there is 1 x 15A1170 on it - which is not only too wide but to short (its rubbing against the snout at the front of engine). The belt is only going around the crank and then to the pump (no A/C). My question is has anyone got the correct length of this belt without running the a/c? I went to Bnt and and they said I needed a 13A1450 (Dayco17570) however this is way to long. So I need something bigger than 1170 and (a lot) smaller than 1450.
Any ideas would be very much appreciated
