Hi All,
Im looking for some info on shockers for my 1994 MU, problem is in Australia no one seems to stock anything. can anyone help with some advice on what i need for a 2" lifted suspension MU rear shocks ??
94 MU rear shocks for 2"lift
Re: 94 MU rear shocks for 2"lift
Standard shocks are long enough for 2 inch lift, hilux eye eye shocks are longer
Ok it seems rodeo TF are the same. Which shocks do people rate. I have been recommended to EFS anyone used these ?
Has Anyone in Oz Fitted aftermarket shockers to a 1994 MU ? i have heard the Tf Rodeo ones fit but apprehensive to purchase until i can confirm they fit.
keen for any info that will help me get the right shockers, really need to change them.
smithyMU wrote:Has Anyone in Oz Fitted aftermarket shockers to a 1994 MU ? i have heard the Tf Rodeo ones fit but apprehensive to purchase until i can confirm they fit.
they will.
if you want to be 100% take one out measure its length eye to eye while its extended and compressed and then compare
they will.
Cheers Josh,
I have springs from another MU ( Cow car ) you may have seen it on here, im not sure how high they will lift the rear tho.
Front i was looking at ball joint flip and adjust the Torsion bars,
how did you achieve the 2 1/2" lift on your MU and what shocks do you run ?
i thought the cow mu had patrol diffs and coil springs?
that was my last car i will update my profile now, from memory it was pedders shocks, springs were replaced by previous owner not sure on the brand.
it also had extended shackles.
i did the ball joint flip, just be aware that it will probably void your insurance if you have an accident and the insurance guy notices them.
