Diesel runs out
Diesel runs out
Hey team, ive got a 96 2.8 diesel Mu which the fuel filter blocked up the primer I changed filter to a ryco filter pumped up etc etc. I did blow compressed air down the lines. Now after driving for a little while and happens more with about half a tank of fuel rather than full it runs out of diesel and I have to take the line off to the pump and prime runs for while then happens again I have changed filters twice put new hose clamps on. Please help
Re: Diesel runs out
How much air pressure did you put into the tank? you have have blown the pickup off inside the tank, definatley sounds like its sucking air
Re: Diesel runs out
Quite a bit of air I blew.
Re: Diesel runs out
So if I have blown the pickup off how and whats the easiest way to fix
Re: Diesel runs out
I think the pickup is on the fuel gauge assembly which is screwed to the front of the tank. You will have to drain the tank first. Why did you blow the lines?
Re: Diesel runs out
Because the primer wasn't priming up and to check the lines were clear. Cool thanks hopefully thats it
