Rear Main seal 4jb1t
Posted: Mon Sep 07, 2015 9:12 am
by topgun94
SO - After many of hours trolling the forums across the internet. I came to the conclusion that this time when i replace the Rear main - i would use a genuine ISUZU seal to prevent ANOTHER leak.
I had my clutch replaced 20k ago and at the time had the rear main replaced (Which was leaking) - They replaced it with an aftermarket ONE piece seal.
This Aftermarket seal is a double lipped seal that is easily pushed in with your fingers and/or small amount of hitting with blunt chisel /rubber mallet.
The GENUINE isuzu seal is what at first glance a one piece seal. Upon further investigation it would seem it is a two piece seal. In the third picture you can see the inner and outer ring seperated by what seems to be a soft foam of some description.
the inner ring easily rotates around within the outer. This seal IS NOT able to be pushed on with my fingers. And due to the Cost (95$) and the construction of the seal i am not prepared to persuade it with a rubber hammer to have it leak again in 20k.
The picture with the boxes was taken from the old forum and my numbers matched the new seal in the plastic bag.
On monday i am going to try and track a tool hire company (and do it myself) or a engine rebuilding shop that will install the seal for me.
Brisbane ISUZU said they could install the seal but takes 1.5hrs at 135Per hour. They charge 135 PH from the depot (about an hour from my house).
Re: Rear Main seal 4jb1t
Posted: Tue Sep 08, 2015 2:15 am
by blairreed
I made a metal band on the lathe at work that sits behind the seal so it gave me something to lightly tap on with the hammer and distribute the load more evenly. only put about 5000ks on the truck since I changed the seal but it seem to be holding up fine. (just and idea if you cant find anything else)
Posted: Sun Oct 06, 2019 8:43 am
by topgun94
Realised i never finished this thread off.
4 years of happy trucking and no leaking rear main seal.
Below is a link to the tool i used to complete the job. I ended up just buying one and it works for my 4jb1t and 4jj1 dmax.
https://www.ozwidetools.com.au/gm-isuzu ... ation-tool
Posted: Sun Oct 06, 2019 11:18 am
by paulthepilot5
I was about to reply and say I have a seal tool I made you could borrow, guess I’m 4years too late :lol:
