In the bar as its not isuzu
What are your thoughts on the following saga
2007(i think) holden captiva diesel
This is a car at work and not one Ive had anything to do with and I would never touch it with a barge pole.
Since new its had ongoing problems with flat batteries. Its spent more time in the garage than on the road. Its under a lease settup but somehow we still end up with the costs. Comes time to sell it and the lease co wont accept it back untill the flat battery problem is fixed.
Its spent the last 2 months at the local Holden dealer. They now say its fixed but not a warrentee problem as the cause was that whoever fitted the towbar had clipped into the tail light wires (just like any normal car) instead of wiring off a separate connection on the computer and this had fried the computer wiring loom and a dozen other things. Cost to fix $7k
We would of been better having it fall off the ferry in the middle of Cook Strait.
What are your thoughts on this diagnosis.
options are
Likely It happens all the time
possible
unlikely
Dont believe it
or my favorite form of fertiliser?
Holden captiva problem
Re: Holden captiva problem
yes they do toast ecu if you tap into the tail light wiring, they run CAN Bus, whoever fitted the towbar should pay for the repairs
I would be removing the tow bar and associated wiring and taking to another holden dealer.
Or chase down who did the wiring for the tow bar.
