oil problem 2001 deisel wizard
Posted: Mon May 06, 2013 2:05 am
by butch49
hi all i have a 2001 wizard deisel with the 4jx1 engine , the oil light started to stay on for upto 30 seconds at cold start up had it looked at was told that it appeared to be a wiring fault as when they did oil pressure test from oil filter had heaps of pressure problem then went away for approx 9 months untill yesterday when the light stayed on again for extended lenght of time as it went out my turbo started to whine hence 1 blown turbo has any one out there had the same problem A is it a turbo problem or B low oil pressure at top of motor all help greaty appriecated
Re: oil problem 2001 deisel wizard
Posted: Mon May 06, 2013 3:30 am
the turbos arnt the best is replaced with a chinese one, need to do a oil pressure test at the oil pressure sensor and see what it is when its playing up, the oil pickup o rings have faults, it could also be a wiring fault though
Posted: Tue May 07, 2013 6:09 am
by butch49
the turbo was replaced with a genuine unit had o rings replaced with turbo then had them replaced 9 months ago when oil light problem arose also had oil pressure test done at same time had instint pressure , light stayed on other day then as i moved off light went out turbo whined and ideas cheers
Posted: Tue May 07, 2013 6:22 am
low oil
oil contaminated with diesel
damaged oil pump/s
Strainer as per robs post
After market oil filter with no anti drain back.
Should always wait for oil light to go out before revving engine
What mileage?
Posted: Tue May 07, 2013 8:02 am
if it was mine i would just run a machanical oil pressure gauge in it to make sure as it has been a problem for a while, sounds more electrical than machanical if you have had it checked out and its still going would have run a bearing in the engine by now with no oil pressure
