Just need some rodeo help my ute keeps eating CV's
All Club management, news and development discussion
Forum rules
* Above all, play nice
Re: Just need some rodeo help my ute keeps eating CV's
There is a needle roller bearing that holds the cv in the front hub check that and make sure it has the circlip on the end of the axle to stop it from moving in. Also the only good CV's are the factory ones
Also you might need to pump up the rodeo it looks a bit flat in the video ;) ;)
iananita
Post by iananita »
Have you removed bump stops? or shaved them?
Your other video shows heaps of flex in the front maybe too much for the CV's.
