DIY front seal replacement
Posted: Sun Jan 15, 2012 1:58 am
This is how i change the front seal on a belt drive motor
Follow the instructions in the timing belt FAQ viewtopic.php?f=27&t=172
Then i use this tool to hold the crank so i can undo the main bolt
Crank Tool.PDF
You will also need a tension wrench capable of torquing the bolt to 205Nm/150ft-lb
THIS IS IMPORTANT
Then just prize the old seal out and tap the new one in with a piece of pipe
Crank Tool.PDF
THIS IS IMPORTANT
