Page 5 of 5
Re: Wanted 4jg2 Power steering oil pump
Posted: Fri Mar 18, 2016 5:52 am
by mrsuzu
I mean the whole hose thing with connector ?
Posted: Fri Mar 18, 2016 6:23 am
The part I showed is the part that the hose fitting bolts on to. You need the complete hose not the part I have.
If the isuzu is there but has no hose have a look round other cars to see if you can find one that fits. Try it on the wrecked isuzu before paying
Posted: Fri Mar 18, 2016 7:12 am
by mrsuzu
geeves wrote:The part I showed is the part that the hose fitting bolts on to. You need the complete hose not the part I have.
Thank you. There is one isuzu on trademe http://www.trademe.co.nz/Browse/Listing ... 1034388070,
This got run bearings because of incorrect oil, its a 1997, please have a look and tell me how much is its real worth? Cheers
Posted: Fri Mar 18, 2016 8:20 am
Why are you looking at complete cars?
On the face of it the price seems reasonable. The engine is the valuable bit. You would have one issue with a motor swap. The 97 will be electronic control. Options would be swap injector pumps or deal with a check engine light. Might be other wiring issues but not unsortable. Had it been auto could of been more issues.
Would of cost a lot of money to recon and then they ran the wrong oil? Even cheap petrol oil wouldnt of killed it that quick. Could be ok but treat with caution
Posted: Sat Mar 19, 2016 3:11 am
by mrsuzu
geeves wrote:Why are you looking at complete cars?
Yup you got it, Wanted to swap the motor, But i will take your advice i will stay awy from it. cheers for that good suggestion, I've got that hose and wee connector cost me 60 bucks, is it an ok price? Damn i should have bought it beofre rather welding it...
Posted: Sat Mar 19, 2016 4:14 am
by mrsuzu
I have got noise coming from dashboard specially when accelerating from lower gears, i assume something inside dashboard it touching with something, Is it easy to open the whole dashboards, Where do i start from?
