Regan's Moo
Show us your Rig!
MrRevhead
Re: Regan's Moo
Post by MrRevhead »
What the hell did you do to manage that? Must have been in the arvo as I saw you drive up Queen st just before lunch.
Downhillnz
Re: Regan's Moo
Post by Downhillnz »
Was doing something I know I shouldn't have been doing. It dropped all the oil out of the sump...
And that was the aftermath. Can't see very well but the windscreen is smashed and the back guard is pushed up badly.
MrRevhead
Re: Regan's Moo
Post by MrRevhead »
Oh dear.
How buggered is it?
Re: Regan's Moo
couple new panels and the body will be fine. You didnt even break the mirror. Just a question of how much damage the fire did.
Downhillnz
Re: Regan's Moo
I broke the glass in the mirror sadly.
Anybody done a body swap?
MrRevhead
Re: Regan's Moo
Post by MrRevhead »
If you can do a chassis swap, not a body swap ;)
Downhillnz
Re: Regan's Moo
Well I've sussed another complete moo. I was going to do a body swap. The new body is nice and straight :)
MrRevhead
Re: Regan's Moo
Post by MrRevhead »
What I was getting at was to do with the chassis numbers on the firewall. So whilst you will put the new body on your chassis. For rego purposes (assuming the new MU has live rego?) It will probably be easier and cheaper to use the rego of the new one rather than much around changing vin numbers etc.
But it would be best to talk to VINZ etc first to work out which way to go.
Downhillnz
Re: Regan's Moo
I hadn't seen chassis numbers on the fire wall? Only the VIN number? Which is only to show that it has been imported into NZ.
I was planning to swap the VIN numbers over because mine has reg and wof. As far as I'm aware..... the chassis code is on the physical chassis and me removing the vin number and putting on the new body isn't illegal?
Hopefully someone can come in and correct me if I am wrong.
Re: Regan's Moo
not illegal but it can get complicated If it ever needs any form of comliance ie low vol cert etc they do check the numbers match. When they dont you get asked lots of questions
