Intake valve 42mm.
Exhaust 35.5
4JB1T
Intake 40mm
Exhaust 35.5
I'm using the 4jg2t cam....no interference issues.
I was not aware of a difference in 4jg1 and 4jg2 cams. Is there a difference. I also have been using the 4jb1t 4 hole nozzles and am going to try swapping in the 4jg1t 5 hole nozzles. Hopefully better and more complete burn yielding a more efficiency.
Do you guys have any suggestions for more fuel efficiency.
Stock 4jg2t downpipe, to 1999 Trooper 6vd1 stock 2.25" exhaust.
Subaru STi large hood scoop for better air flow over intercooler. I think I need to change over to a fmic eventually.
Running 31" inch tires (305/65R17) Mickey Thompsons
Timing is set to .55mm @ 12°btdc.
Book says .50mm @12°btdc....but I read somewhere if I can advance that by .05mm it has better performance and fuel efficiency. So far only seeing 22-23mpg or 10.69-10.23L/100km
I love this Trooper and intend to keep it as long as it will keep me. I believe this is the only Trooper in North America with this engine setup as far as I have read and seen online. All parts are accessible through local isuzu industrial and highway parts dealers...if you have the part numbers it makes it a lot easier. I found the most of my larger parts from http://www.freewai.com and searched 4jb1.
