Wanted 4jg2 Power steering oil pump
Re: Wanted 4jg2 Power steering oil pump
Geeves any luck ?
My Wizard has the same hose setup
Options are
Get an engineer to braze it back up as Rob suggests. This will be as strong as original
Visit a hose Doctor. They may have one on the shelf
Holden dealer might be able to supply but if Rob is correct this might not work except a complete new hose
Only other suggestion is that subarus have a similar pump so might have the same coupling
Options are
Dont braze it, as it will leak as bronze is porise, easyflow or sylfloss it back together, the hose doctor has cut the original crimp fitting off and easyflowed the treaded fitting on the end for the new hose to screw onto, genuine hose comes with it all attached and is around $135, i would be welding it back together, easy fast fix
geeves wrote:steerbit.jpg
Is this the bit? I took the part to brake and hoses and they fixed it I would say nicely weld. Thank you for your responses and for looking the part for me. I wanna ask the idling speed stays on 1000 rpm per minute on truck. Is this normal If not how do I adjust it ?
Is it auto?
Air con on?
Book says 850 but if auto when very cold the check trans will flash when coming to a stop(should wind mine up a bit)
Air con on?
isuzurob wrote:Dont braze it, as it will leak as bronze is porise, easyflow or sylfloss it back together, the hose doctor has cut the original crimp fitting off and easyflowed the treaded fitting on the end for the new hose to screw onto, genuine hose comes with it all attached and is around $135, i would be welding it back together, easy fast fix. Thank you rob. Welding was an easy fix but still cost me around 4o bucks. I have put it back now it's nice and soft again. In case it break next time gotta change it with new part the easy flow one. How ever there are some squeeking noises coming from steering wheel now when I turn it right to the either end. Any clue. Cheers for that rob.
geeves wrote:Is it auto?
Air con on?
Book says 850 but if auto when very cold the check trans will flash when coming to a stop(should wind mine up a bit)it is an auto but not actually with aircon on. 850 and 1000 no big difference. Do you think it's all right. No that light doesn't appear.
Air con on?
sounds like the drive belts are slipping and need to be tighter
Could be just oil on them as well.
geeves wrote:Could be just oil on them as well.there is oil all came from reservoir should i take it to washbay and give a good engine wash.
