Page 2 of 2
Re: Looking for a Bighorn
Posted: Mon Sep 21, 2015 6:18 am
by MrRevhead
That had happened to my MU. Entech here machined out a wide key way slot and machined the pulley to suit. Saved the crank.
Posted: Mon Sep 21, 2015 7:36 am
by Downhillnz
Did that involve removing the crank?
It was only the gear Geeves, not the other bit.
At this stage I have a fresh keyway and gear and I'm going to weld it into the crank. Obviously replacing the main seal before I do so!
If we still have it after that seal goes then Ill replace the crank/motor
This is what happens when backyard hillbillies do cambelts :(
Posted: Mon Sep 21, 2015 8:36 am
by MrRevhead
Haha yes the crank came out for that
Sound's like a hill billy is doing the repair ;)
Posted: Mon Sep 21, 2015 5:35 pm
it is a common problem, i get new timimg gears made 10 thou smaller and heat them and fit them to the crank, good luck getting them off again
Posted: Tue Sep 22, 2015 5:37 pm
by Downhillnz
isuzurob wrote:it is a common problem, i get new timimg gears made 10 thou smaller and heat them and fit them to the crank, good luck getting them off again
I take it when the oil seal goes then its tough shit?
Posted: Wed Sep 23, 2015 6:57 am
can heat them i guess to get them back off, and i have a special puller to pull the gear off, the crank oil seals last for at least 200,000km
Posted: Thu Sep 24, 2015 9:06 am
by Downhillnz
This goes from good news to good news. I had a weird exhaust noise which sounded like a leak.... Ends up its the manifold to turbo. I have seen so far one bolt is missing.
This is a weird vehicle. The egr has been removed in a professional manor, but other stuff has been bro'd up
Posted: Fri Sep 25, 2015 2:03 am
If its the turbo end it should be easy
Posted: Fri Sep 25, 2015 8:47 am
by Downhillnz
Is it common for the manifold to turbo bolts to fall out?
Remembering this has done 350ks. Bolts do age I guess
