Page 2 of 8
Posted: Sun Jun 21, 2015 5:02 am
by SamMu93
Looks like it will end up costing quite alot when you add up the total of all this:
Leaf springs
Ubolts
Bushes
Installation labour
Labour to wind up torsions and flip balljoints
Cost of a wheel allignment
By my estimate you would be looking at $800- $950 all up
Posted: Sun Jun 21, 2015 9:17 am
by nb422
Spring over, body lift, and cert. Easy
Posted: Sun Jun 21, 2015 7:15 pm
options 1,3and 4 sound good You dont want opt 2 in a Mu. It would be wise to add greasable shackles and pins to that kit of you will be hounded by squeaking bushes for ever more.
Labour should be no more than personal garage time. Do the rear springs in a morning spray the front adjusters with your favorite penetrating oil Have lunch Do something elese for the afternoon. Following day spray the adjusters again lift one side flip the joint wind the adjuster up about 2 turns Drop it lift the other side do the same but also take the linkage off the roll bar Take it for a drive round the block then final spring adjustments.
As for spring over Did it actually pass?
Posted: Mon Jun 22, 2015 7:26 am
by nb422
Went over it with certifier and he was happy with it as long as welds were good. Official cert inspection is tomorrow morning so will let you know.
Posted: Tue Jun 23, 2015 3:29 am
You have a separate thread on this. Can you publish the suspension measurements once its certed. It could make usefull info across the 4wd scene in the future
Posted: Tue Jun 23, 2015 5:36 am
by SamMu93
Not sure if Ill go with ironman springs as I recieved an email today saying they would raise it 40mm and cost $760 all up.
Seems abit steep but once I get a quote from my local Ill decide.
Ironman:
This gives you a 40mm lift (from new). If you went for our ‘Performance’ leaf springs, they have a capacity for 0 – 300kg additional weight. They should be fine for your vehicle. The constant load leafs have a capacity of 300kg up to GVM and they would ride hard if you didn’t have constant weight in the back. So, if we went the Performance Leafs 2 @ $233.75 + GST each, the UBolt kit 2 @ $33.00 + GST each, the bush kit @$82.50 + GST and freight @ $45.00 + GST the total will be $661.00 + GST of $99.15 = $760.15 GST Inc.
Posted: Tue Jun 23, 2015 5:54 am
Time to pick up a phone book and ring all the wellington parts suppliers. ie repco bnt sas hut city auto parts autoline etc
Posted: Tue Jun 23, 2015 7:06 am
by SamMu93
Yeah, tried supercheap, hutt city autoparts, repco, 4wdBits, SAS... Time to put down the phone book...
Posted: Tue Jun 23, 2015 5:36 pm
by slightlydodgy
Would be 7 or 8 years ago but bnt did me a hd set for my rodeo for $450 They were 50mm lift over standard
Posted: Wed Jun 24, 2015 6:09 am
lovells still make them i payed 950 for a set of 50mm raised and have had them reset twice in 1 year they keep sagging, just get your original leaves reset 50mm, it cost 350 for both leaves i got some reset 75mm for my LWB 89 bighorn and they still flex very well
