puting extended shackels in need advice plzzz
isuzumu4wd
Re: puting extended shackels in need advice plzzz
do u flip the hole top a arm??
No you don't flip the whole top "A"arm. As Geeves detailed earlier, you are just completely removing the ball joint (from both the arm and the spindle casting/forging) and bolting it to the otherside (underside) of the arm and returning it to the taper in the spindle.
isuzumu4wd
