EGR Removal
rcolijn
Re: EGR Removal
Post by rcolijn »
Thanks guys, I would like an extra battery so that kight be a good reason to do it. Will have a think about it. Good stuff, this forum always helpes me out!!!
muzila
Re: EGR Removal
Post by muzila »
Just in case anyone wants it I did a PDF file finally of the EGR removal. It is the same as the one here.
MattWest
Re: EGR Removal
Post by MattWest »
I have a 95 auto, 3.1, with working aircon. From what I can see the 2 vac lines from the egr valves head to some electrics by the booster. I want to keep anything to do with the aircon working - ie fast idle. In this case what do I do with my vac lines? follow the above pics? or is there some thing else I need to do?
I will get pics up of the solenoids etc, but can I remove all of these? what do you do with the lines that run to other places, just block them up?
Cheers, hope that all makes sense
Captcol
Re: EGR Removal
Post by Captcol »
From what I understand those two solenoids can be removed, I have just blocked the line coming to the solenoids as I haven't had time to trace it back yet. Which reminds me I need to fix the fast idle, it works it just doesn't touch the throttle so jumps in and out without affecting anythings
MattWest
Re: EGR Removal
Post by MattWest »
So, Ive just changed the cam belt in the Mu, and removed the EGR valves and now have some issues.
Ive set up the vac lines as above (hoping this is the same for the 3.1) and now wont idle and is running rough as guts. Im trying to figure out if this is something to do with the vac lines and egr, or Ive go issues with cambelt and timing etc.
Any suggestions/comment would be helpful.
Re: EGR Removal
double check timing
MattWest
Re: EGR Removal
Post by MattWest »
geeves wrote:double check timing
Yes, will do. (dammit)
Set the vac hoses up as per pic in the thread below, and no luck. def must be timing.....back to work!
viewtopic.php?f=23&t=826&start=0&hilit=3+1+egr
MattWest
Re: EGR Removal
Post by MattWest »
so.. Ive hunted and hunted to find some infor on how to line up the marks on the injector pump gear and also cam gear with no luck. Can anybody point me in the right direction? Have No.1 at tdc but marks dont make sense at the mo.
Re: EGR Removal
It's all in the FAQ section
isumu
Re: EGR Removal
Post by isumu »
Hi All
So to keep air-con running as usual, what exactly are the extra steps I need to do (if any)?
