Mudstuck free wheeling hub
Renier
Post by Renier »
Has any one fitted a pair of mudstuck freewheeling hubs my auto ones gave so I've bought a pair but I seem to be missing something the cir clip I have is too small i can always get a bigger one but will need heaps of spacing washers to hold the axle in is this normal?
Re: Mudstuck free wheeling hub
I have only used genuine hubs, circlip only holds axle in the hub so spacing it will work as long as the rest all works
Renier
Post by Renier »
I just found my issue someone has put the wrong cv in on at some point when I checked the outher side it has a second circling mounting for manual hubs... I'll do some careful mesuring and pack it out with a few washers on this side not worth replacing the cv I don't think
There should be 2 slots for the circlip. The smaller one is for the auto hub but if you can shim it out to fit it should be fine.
There are no isuzu hubs on the mudstuck site but the other ones look like either AVM or a cheap copy.
A photo might help
Renier
Post by Renier »
Got these on I found that when the auto hub failed it compleat ly sheered off all the teeth that made up the 2nd slot so did a new cv the mudstuck hubs look like a asin hub with a 5 year warranty seem to be ok quality but only time will tell:)
Have a look at these 2 links
https://www.aliexpress.com/item/ISUZU-P ... autifyAB=0
https://www.aliexpress.com/item/FOR-ISU ... autifyAB=0
These are most likely what mudstuck is selling. Some of his winch deals are quite good but always double check what you are getting. He used to sell a polyester 9 meter snatch strap. I foolishly bought one but only use it as a short winch extension. It has about as much stretch as chain. We tried it under test conditions. Toyota surf plus bighorn on hard grass light snatch of about half walking pace and all my fillings fell out
fujitsubo
Post by fujitsubo »
I brought a pair of steel FWH from mudstuck awhile back, they lasted about a year before self destructing that was with daily use in 4wd and lots of abuse. I used a 3/8 stihl chainsaw rim sprocket which sildes over the end of the axle and a 10mm bolt to hold it in as the end of the splines are threaded, spaced it out perfectly to stop that annoying cv rattle.
Renier
Post by Renier »
Those aliexpress ones look the same as the ones I got only paid $175 for them and so called 5 year warranty I looked at aliexpress ones but with shipping and near no comeback on their products I went with a nz shop :)
