Hi, I have a 1997 wizard with a efi pump in it. I would like to convert it to a manual pump.
Can anyone advise me on whats involved in doing it please.
Efi to manual pump
Re: Efi to manual pump
Ive just moved this to the correct place.
Manual pump should just plug and play but Im not sure if the efi uses a proper throttle cable. If not then its more work
EFI has better power and ecconomy
Can anyone tell me how hard it is to put a head and pump off a non efi on to a efi engine?
The head is the same. Just standard head and gasket swap. The pump is just timing belt 4 bolts pulley and pipework. Only catch is if your car was an efi model you might have a fly by wire throttle and how it talks to the auto trans is different. If you are dropping an efi motor into a non efi truck then swapping the pump is all you need to do
Thanks, my donor head and pump is non EFI going into Efi
Heads are the same but I think you will have problems with the pump. Better to rebuild your efi pump if it needs it
