4jg2 problem
stardog
Re: 4jg2 problem
Post by stardog »
I bought a new starter motor should be by next Thursday it seems to be starting better since I changed the earth cable but still dropping down on the volt meter.
stardog
Re: 4jg2 problem
Post by stardog »
Changed the starter motor today starts first turn of the key again so the starter was stuffed it looked very new but you can never tell.
Bad news is I still haven't got any fans or air con working in the cabin grrrr im not sure what to look for on the wizard if it was my mu different story.
Has anybody know what could cause this with the fans and air con.
Re: 4jg2 problem
mu and wizard are essentially the same
stardog
Re: 4jg2 problem
Post by stardog »
My 94 mu doesn't have climate control its the same as Holden rodeo to 97 levers not buttons its the same as fronteras controls all electronic push buttons.
Re: 4jg2 problem
still all affected by the charge relay
Re: 4jg2 problem
I just had the same fualt in my 89 bighorn, and that is a complex system, best way is to find a wiring diagram, mine has 2 inline fuses by the steering colum, a resister in the heater box and 4 relays the charge relay is one of them, then to a relay behind passenger headlamp the is earthed by the oil pressure sensor on the engine (this relay was faulty on mine) have ac and blower fan again, then i had a high speed relay and mid speed, The systm works on constant power to the fan and resists the earth for fan speeds, well thats how mine was
stardog
Re: 4jg2 problem
Post by stardog »
Thanks for the quick reply's guys
Brand new brown charge relay installed when I changed the alternator over the battery is also new and new starter motor.
Getting charge on multi meter 14 volts to battery when running.
I will see if I can find the wiring diagrams in the manuals I have for jackaroo and fronteras but the v6 petrol might be different set up to a diesel.
stardog
Re: 4jg2 problem
Post by stardog »
I think I have a couple of bad relays in the fuse box in the engine bay can I use normal 4 or 5 pin relays instead of the jideco ones except the charge relay.
Re: 4jg2 problem
check the numbers on them. There are different configurations
stardog
Re: 4jg2 problem
Post by stardog »
There are no numbers on the relays only the brown charge relay the good thing is my air con and fan are back working again.
The black relays look like normal relays in the pin set up 5 pins but only 4 pins are used in the socket.
