Looking for a Bighorn
Re: Looking for a Bighorn
That had happened to my MU. Entech here machined out a wide key way slot and machined the pulley to suit. Saved the crank.
Downhillnz
Did that involve removing the crank?
It was only the gear Geeves, not the other bit.
At this stage I have a fresh keyway and gear and I'm going to weld it into the crank. Obviously replacing the main seal before I do so!
If we still have it after that seal goes then Ill replace the crank/motor
This is what happens when backyard hillbillies do cambelts
Haha yes the crank came out for that
Sound's like a hill billy is doing the repair
it is a common problem, i get new timimg gears made 10 thou smaller and heat them and fit them to the crank, good luck getting them off again
Downhillnz
isuzurob wrote:it is a common problem, i get new timimg gears made 10 thou smaller and heat them and fit them to the crank, good luck getting them off again
I take it when the oil seal goes then its tough shit?
can heat them i guess to get them back off, and i have a special puller to pull the gear off, the crank oil seals last for at least 200,000km
Downhillnz
This goes from good news to good news. I had a weird exhaust noise which sounded like a leak.... Ends up its the manifold to turbo. I have seen so far one bolt is missing.
This is a weird vehicle. The egr has been removed in a professional manor, but other stuff has been bro'd up
If its the turbo end it should be easy
Downhillnz
Is it common for the manifold to turbo bolts to fall out?
Remembering this has done 350ks. Bolts do age I guess
