want to do hidden winch
JohnWilson
Re: want to do hidden winch
1omm plate for base 7mm for sides just thick angle iron to were the nudge bar bolts to
JohnWilson
10 mm plate for the bass and 7 for the sides sorry no pics of the chassis mount
mate now you have done one would you fab up another one or two to order possibly could be a market for it
i know this thread is quite old but i am very interested in that winch set up any chance you may still have measuerments lying around for that winch set up at all ???
any chance of measurement you used for that mount very keen to do something similar with my swb
danz20 wrote:any chance of measurement you used for that mount very keen to do something similar with my swb
Measurements depends on what are you up to fit in your swb.....you can go for a regular 8000 pounds electric winch to a massive Warn 8274.....both pictured here below
You can get some ideas out of the Ramsey website where you can download several mounting applications for several vehicles manufacturers and then customize yours.
Not sure if you have welding skills .....if not, demand the help of a good/qualified welder unless you like the idea of flying winches...
cheers!
cheers!
If you do a search under my username you will see a bunch of pics on my winch mount.
Mine has proven very strong. Snatched and winched both my truck and patrols, land cruisers and other big vehicles.
The front of the Isuzu's are hard to do an easy mount on.
yea wont be a massive one will be something very similar to the above photo
viewtopic.php?f=30&t=6474&p=40538#p40538
For whoever it was that couldn't find my build thread. Just do an advanced search and specify the author if you need to search again in the future
