2.5" Dump pipe for 4JB1T
lucasks82
Re: 2.5" Dump pipe for 4JB1T
Post by lucasks82 »
Do I modify my existing oil filter setup? How?
Or do I source the angled oil filter setup? From what model?
as my post above, you need the filter housing and pipe work off a 98 on 4jb1 out of a rodeo or one off a 3.1 bighorn/jackaroo, the filter pionts down towards the front diff
lucasks82
Post by lucasks82 »
ok thanks. I will try to source the filter housing and pipe work you mention so I can fit the 2.5" dump pipe.
Cheers for your help, I hope I have some luck and can find the gear
nb422
Post by nb422 »
lucasks82 wrote:are the cheap snorkels ok or should I fork out for a decent one? What brands do you suggest?.
Pay the extra for a quality one, or if you want to go all out get a custom stainless one. I bought a cheap snorkel and regretted it immediately, very weak and poor fitting
lucasks82
Post by lucasks82 »
thanks.
I have actually seen safari snorkels on ebay for my truck for only $350 so that would be the go for me I reckon
An x member here that no longer goes 4wding had changed to Vitaras He sold one vitara to a young guy that rolled it. He then bought the snorkel off the wreck and refitted it to his new truck. Snorkel had a few stone marks in it but was fine. That was a safari snorkel
lucasks82
Post by lucasks82 »
that sounds like a tough snorkel. safari is at the top of my list.
Also I have found a guy about 100km away who has a 98 rodeo for parts and he says the oil filter points east west - down the front of the engine. Does that sound right?
I thought in the 98 they are vertical and facing straight down, is that right?
97 rodeo the filter points down on a 45 degree angle in a north south position, it sits just above the front diff head
what about the v6 or 2.6 petrol engine? Neither are any use in this case though
lucasks82
Post by lucasks82 »
I have been to a local exhaust shop and he suggested just doing a 2.5" exhaust from the existing 2" dump pipe.
Is that a good idea?
I mean wont it constrict the air flow right from the turbo and negate some of the benefits of having a big bore straight through exhaust?
