Hi i have the following bits for sale that i no longer require, all where only removed for upgrades. Will take offers on the parts, as i dont need them and want them gone prices will be pretty low.
Stock black front bar
http://tinypic.com/m/i3uipl/2
Modded alloy jackaroo bar (only removed for arb bar install) and side wind deflectors
http://tinypic.com/m/i3uiqc/2
chequer plate side steps
http://tinypic.com/m/i3uiqg/2
Small front bar with lights
http://tinypic.com/m/i3uiqq/2
exhaust from turbo back
http://tinypic.com/m/i3uiqs/2
FS: Bullbar, steps, exhaust, more Brisbane
Re: FS: Bullbar, steps, exhaust, more Brisbane
Hi Mate how much do you want for the parts?
also is the exhaust standard one or larger? if larger what is the diameter?
Thanks in Advance
Andrew
Thanks in Advance
Andrew
Which parts are you chasing, or are you after the lot?
I think its a 2.25 or a 2.5, steps up after the first section from the turbo which isnt in the pics but is included
Hi mate I'm interested in the modded jackaroo bar and the exhaust but only if it is definitely larger diameter.
Also did the jackaroo bar fit on ok on the mu? Have you got any pics of it?
Andrew
Andrew
Heres the bar, only removed it as i found an arb winch bar.
Exhaust measures approx 55mm and steps up from factory as the exhaust turns behind the gearbox.
Hi,
I have a 92 MU 2.8 Td. Will it fit this?
Am looking for a replacement front bumper bar. Mines chrome, but has been pressed in a bit at the centre (I nudged something!)
How much for your stock black front bar?
Im pretty sure it would, $40?
No worries. Is yours off a 91 2.8 td MU?
If so. I'm interestered.
Where are you located in BNE?
sorry for the late reply, holidaying in NZ (astounded by the amount of isuzus over there)
Yep thats exactly my model, im at keperra
Hey mate how much for the rodeo bull bar
Cheers peter
Cheers peter
