The 89 2.6 trooper project
drinksoptional
Re: The 89 2.6 trooper project
Sorry if its a big read anyway this is where i am to date. I move house next week so this project will have to wait plus the engines is 210 miles away as it wouldnt fit in the back of the bighorn on a pallet i will use a box trailer to get it home
the joys of salted roads
thats a biiiiig project
good luck
good luck
drinksoptional
I tell myself it will be worth it in the end i would like to put it back on the road by end of year
drinksoptional
I stripped out the radiator some pipes, wires an loosed the bolts for the down pipe . Im getting engine ready to be lifted out then i will drag it onto set of car ramps to get the gear box an props off . Then i will get mates 500kg engine lift an whip the 2.6 out. My friend delivered the 3.1td and we unloaded it onto a pallet on my driveway.
I have been working when i get time . I removed the front wings and bonnet , i also removed the rear doors.
The rear doors are rusting badly at the bottom i will cut away the crap an replace with new
The wings are rusted too shit at the bottom where they meet the sills that why i removed them also wanted to check the sills behind the wings . i will replace the corroded parts
The bonnet i removed so i can get the 2.6 out and the 3.1 in. I then have to cut a hole for the intercooler
drinksoptional
he removed back doors picture no reason for it but we all like picture post`s :lol:
Next job was removing the gearbox so i attached a strap to the bighorn and dragged the trooper onto a set of ramps.
I unbolted prop from the rear diff flange . Then i hit an issue with this bit
Two bolts were missing on passenger side qand looked like it was welded on when i tried removing the bolt it snapped the mount dropped a bit. The other side i used a blow torch to heat was all i had it was too windy and cold i ended up snapping another bolt an the other one wouldnt budge so i stopped there before i snapped another one. Will by some penetrating spray see if i can get that to help
drinksoptional
Im back this week GEARBOX
First off i had bought a work lamp on a Tri pod for a tenner chance find in a recycle place had it in a corner swap me it for a tenner Scottish money 8-) It had a socket so i swaped that for a plug and fitted a new bulb. Then out into the garage tent last night.
I wanted the rear shocks off as they are new standard an the ones on my bighorn are knackered an do not match been like that since i got it in feb. While i was under there i soaked those siezed bolts with some oil
Temptation got better of me so the gearbox mount was coming off an with some leg foot action on a bar off those siezed bolts they came without shearing . Feeling lucky i carried on and started doing the gearbox bolts while doing them Kev next door jumped the fence an came to have a nosey and help as he was bored.
With some twisting levering of it came .
drinksoptional
.Next was engine mounts nuts and then we thought " can we lift engine with a scaffolding bar " could we f**k !!
So that the 2.6 engine ready to be lifted out , quite chuffed now once i get the engine out this build can get going
drinksoptional
Engine lifting out day.
That little plate got ripped off
Just to get the 3.1 turbo diesel in now
drinksoptional
I will let the pictures do the talking.
The trooper now has a 3.1 td fitted just to get the gearbox exhaust fuel tank fitted then get all the wiring sorted
.The trooper now has a 3.1 td fitted just to get the gearbox exhaust fuel tank fitted then get all the wiring sorted
drinksoptional
Ok jeez been a long time since on here.
well i moved house again life love and illness i still have the mk1. I did get it running and it did drive up a small grass hill of my new house . That is it i have been busy sort7ng the grey Bighorn over last three years i think i got 20 hours of work. Major pita it been ofv the road due to leaky fyel pump and welding lots of it. I try boost some pictures and vidies up soon
