Loss of overdrive 1989 2.8
teach
Post by teach »
After doing a little more research, I think the reason why my automatic transmission is not changing into high gear is something to do with sensors.
A couple of posts on this and other forums talk about TPS sensors.
Losing overdrive seems to be a fairly common problem.
My question is this. Are there any good diagrams or pictures that will show me what I need to be playing with?
Are there a few things I should be looking at.
I want to become more mechanically minded and do small jobs myself. I am a little embaressed to admit on this forum that I have only just learnt how to change the brake pads myself. Luckily a workmate has a good workshop and has been showing me how to do lots of stuff, but he does not know Isuzus and can't help.
Any ideas or hints?
I can't contribute much in the way of mechanical advice to the forum myself, however I can give trout fishing advice for Otago/southland!
4x4SWANNY
Re: Loss of overdrive 1989 2.8
Post by 4x4SWANNY »
Wish i could help ya mate...We spent 5 grand fixing wifes ubs69 V6 auto...To complicated for this kid.
Saw the Auto in Parts at the shop...Man they are a maze of bits...Then 6mths later the torque converter bolts came loose and stuffed the seal..I took out auto and fixed that though..If Auto is stuffed just buy a whole second hand one they to dear to fix.
We only fixed wifes because we had the money and she loves here baby lol..If it Packed up now i would Wreck the truck..lol
electrifying
Post by electrifying »
Hi Mark,
What i suggest u do is just unplug this sensor wire:
(it's the one just below the A/C or powersteering belt (u should have 2 belts side by side), just to the left of where that red line points)
It has a terminal like a male spade-lug.
All this sensor does is allow the trans to go into overdrive when the coolant reaches the correct temperature.
This is because the engine coolant will heat the auto-trans radiator (which is built into the engine radiator) so it is the correct operating temperature (which leads to the correct viscosity of the trans fluid), therefore allowing the transmission to operate normally.
If you un-plug this wire, all it will do, is it will allow the transmission to change into 4th gear (overdrive) when the engine temperature is cold.
If the sensor is broken, then your transmission will most likely not go into overdrive.
To compensate for not having this sensor plugged in, just drive gently until the engine warms up a bit, or let it warm up for 5 mins or so (which is good practice, as it also allows other engine fluids to change to the correct operating viscosities)
Im not sure about the O/D light tho. Can't remember what happened to it (as i have stuff on the dash covering those lights).
If this isn't the problem, i think Geeves said on another post somewhere that a filter in the trans may need to be cleaned.
Hopefully all goes well.
By the way, it took me 2 weeks to change the break pads on the rear of my truck, finally discovered that i needed to wind in that allen-key shaped thing to re-set the park break so the calliper would go in all the way, haha. :lol:
electrifying
oh yea, let us know if it works or not
teach
Post by teach »
Cheers for that. I had a fiddle last night in the dark. I couldn't get the plastic lead attachment off the lug part. But I did not want to force it. My mechanically minded mate is going to rip it off for me tonight.
Hopefully it works. I have already sent some enquiries off to online parts stores to get some prices for a replacement sensor.
Thanks for your help.
teach
Post by teach »
Well I got the lead off the sensor. But that made no difference. The o/d off light stayed on and I didn't get to top gear.
I rang isuzu parts specialists in auckland. They have a sensor but the joker there told me that the overdrive sensor is the one on top with 2 wires coming out of it. Not the one to the side as in the photo above. I think I might just have to admit defeat and go to the garage.
I think the next step is getting the Automatic transmission filter cleaned.
Any other suggestions, rather than have my mechanic shag around guessing as to cause.
Its a common auto Go to an auto trans specialist if there is one down there.
electrifying
Sorry to hear that it didn't work, hopefully it's not too serious then.
Although, i don't remember the O/D light coming on in my truck (as it shouldn't when the temperature is low for the sensor).
I do remember a long time ago looking at a wiring test schematic for the auto transmission for a transmission specialist or mechanic to test each gear individually, just by applying a voltage to each wire that goes to the transmission, but i didn't save that PDF at the time (& wish i did cos i wanted to change mine to a tiptronic system), & there are like 8 wires, so would need the wiring info before tampering with anything.
It could be something simple like a loose wire somewhere, but as Geeves said, the auto trans specialist would be the better place (rather than a mechanic), as they would know what the O/D light flashing means, & could probably source the problem fairly quickly.
The other option is that you could put really big tyres on the truck (this would effectively change the gear ratio) & make use of the 3 gears that it does have, so it isn't revving as high when going at 100km/hr :D
chrisprice
Post by chrisprice »
Just fixed my '94 3.1 thanks to fix photo! hurray!!
TomCooney
Post by TomCooney »
Disconnecting the temp sensor worked for me!
